Camaro Research Group Discussion => General Discussion => Topic started by: sedanman67 on May 21, 2013, 01:12:36 AM
Lookin for the value of engiine. Is a 67 MN code 327-275 Camaro engine that was donated by GM to a Community College for the students. Engine was on test stand and was used for electrical problems. Had 30 Hours run time on the meter. It has the 4 bbl intake, pulleys, fuel pump, fuel line, exhaust manifolds, water pump, all original to the engine. Looking for a value as I will be selling it. Does not have Vin stamp on it. Was never installed in a Camaro. Thanks for your help.
ttt
I would think it would be of interest to someone needing an engine like that. Value would depend much on the need for a rebuild, as just the 'out of pocket' parts and machine work would run over $2K...
I would not think it would need a rebuild. Under the valve covers looks like brand new. 30 hours run time on an stand does not equal much wear. I would install a new rear seal and valve stem seals since they are rubber and maybe dry, this would be the time to do that.
Thanks for the reply
When was it donated?
Someone doing a 67 would like to have that - just need to find the right person.
