Camaro Research Group Discussion => Restoration => Topic started by: Dan on August 22, 2006, 12:27:58 AM
I have a '67 L6 that originally had the underhood lamp option (wire clips are still attached to the hood bracing). The original lamp is gone, so I ordered a reproduction for a '67, but instead of the one mounting hole, as shown in the AIM, it has two mounting holes. The one mounting hole is in proper location just as the AIM describes. I have looked at all of the suppliers and all they sell are the lamps with the two mounting holes. What gives?
Dan
Sounds more like a 69 under hood lamp mounting pattern.
Or maybe a 68 and 69. The 68 AIM speaks of existing holes and appears to show two holes (two lines showing screw placement, but interestingly enough only one screw actually drawn). ::)
Yep, original 67 hood lamps have one hole and hang and work upside down. I don't know of any repo's that are correct.
Anyone have a picture of the 67 lamp?
Jeff my 67 has it's original hood light, if you need a pic email me. I got it off while I'm doing my 2nd frame off restore of the car (first one was done in 1988). sbkotula@bellatlantic.net P.S. I'm still looking for that PCV bracket!!!!!!!!!!!!!
Does anyone know if the 67 hood lamp assembly was the same as the Corvair?
Part number 987028 was used for ALL ( Corvair, Chevy, Chevelle, Camaro) in 1967. It was removed from service in January 1968.
Phil,
Yes, all the same for 67. (Corvair, Camaro, Chevelle, etc...)
The same goes for 68 and 69, although all three years were different part numbers.
If you're looking, there's one on EBAY (http://cgi.ebay.com/ebaymotors/1966-67-NOVA-CHEVY-ll-HOOD-ENGINE-COMPARTMENT-LIGHT_W0QQitemZ220023395288QQihZ012QQcategoryZ140705QQssPageNameZWDVWQQrdZ1QQcmdZViewItem) right now!!
Dan,
Bingo! I knew the Corvair light looked like what you had described. If you will look at the Ebay picture that Ed posted, it looks just like the one on my friend's Corvair (hanging upside down). If you want a replacement, look at junked Corvairs or Novas, as well.
Ed & Steve,
BTW, how did you find that info.? The P & A? If the P & A, what was it listed under?
I about tore my friend's P & A apart looking for that lamp, but didn't find it under "hood, lamp, under, assembly" and half a dozen other words...
Phil,
Yup. Group 8.890 "LAMP, Underhood"
1967 ALL - 987028
1968 ALL - 987225
1969 ALL - 993553
Foolish me... We evn looked under "lamp".
If somebody wants to do a study on interpreting the P&A, I'd read it!
Thanks, Ed... again!
