Camaro Research Group Discussion => Maintenance => Topic started by: Kelley W King on May 03, 2013, 05:29:39 PM
How do you change it? From inside?
Same as on a non A/c car, by pulling the passenger side fender, or cutting a hole in the inner wheelwell to get to it. It bolts to the front face of the A/C suitcase body, out there under the fender.
i would suggest the preferred method is to remove or at least loosen the RH fender. .. :)
You could try to take the tire off and take he fender wheel well bolts off and wedge a piece of wood in between the fender and the well.
Jerry
