Camaro Research Group Discussion => Decoding/Numbers => Topic started by: dannystarr on May 02, 2013, 12:18:47 AM
Title: Starter Solenoid Numbers ??
Post by: dannystarr on May 02, 2013, 12:18:47 AM
I just found these in my storage last night. I live in a 5th wheel now, so some things are stored away. Can someone help me decode these??
   1107320  4  F  24   Delco Remy USA
   1107596  6  J  8  Delco Remy USA   6 A
One unit has the extra number and letter. Probably build shift info???  Any help appreciated as all my books are ... well.... ya know... stored...    :-\   Danny
Title: Re: Starter Solenoid Numbers ??
Post by: 67 RS Ragtop on May 02, 2013, 03:01:39 AM
The 1107320 starter was used in '65 Corvette small block applications, and yours appears to be produced June 24 of 1964. I would try the GM parts wiki for the complete application usage, while the second starter appears to be built in 66, September 8th, not sure of application, others will chime in soon.
Post by: bertfam on May 02, 2013, 01:47:47 PM
1107320 was used on several mid 60's applications. I can't find any info on the 1107596.
Post by: JohnZ on May 02, 2013, 03:39:21 PM
1107320 was used on all '64-'67 327 Corvettes, and on many other 327 applications that also used the 12-3/4" 153-tooth flywheel.
Post by: 69pace on May 03, 2013, 11:17:25 PM
1107596 seems to be in wide use starting in 1980 on up for all GM divisions, and on several marine and tractor applications.
