Camaro Research Group Discussion => General Discussion => Topic started by: 69Z28-RS on April 29, 2013, 05:11:57 PM
Interesting article from Hemmings re the Willow Run plant.... maybe we can all pool our money, but it, and convert it to a Camaro restoration facility? :)
http://blog.hemmings.com/index.php/2013/04/29/willow-run-assembly-plant-faces-the-wrecking-ball/?refer=news
There were TWO Willow Run plants - the subject of the Hemmings article is the huge plant Ford built to build B-24's during WWII, which later became the Kaiser-Frazer plant, then the home of Hydra-matic Division, then a GM Powertrain transmission plant, then closed; the other plant was the Chevrolet assembly plant across the highway where Corvairs, Novas, Citations, and Caprices were built, which closed in 1993. I started my GM career at Chevrolet-Willow Run in 1964, building the Corvair and Chevy II.
I went thru the bomber plant several times (it's under 10 miles away) a couple of years ago when they auctioned off the transmission tooling.
Really cool to see where the engines and wings were assembled and met the main body. Looonnnnngggg plant. It make the sharp turn near final assembly so that the plant was all in the same county.
[/quote]
[/quote]
Gee, John, you probably built the car I got my license in - my Dad's '65 Corvair Corsa. Loved that car, leaking pushrod tubes and all - a lot of really good memories from it. Wish I had it sitting beside the 'Maros today.
My brothers '66 Chevy II was built at Willow Run in Apr. of '66. Here's a link to pic. of it on here. It was originally solid color Turq. car with Fawn Interior. And it was as V8, Auto. car. Now sports a date correct 327 with a 350 Turbo. Trans.
My ex-father-in-law (Phil Cartwright) was the Works Manager (Plant Engineer) at Hydra-matic; he facilitized and tooled up the ex-Kaiser/Frazer plant for GM to build transmssions after the fire burned the Livonia plant to the ground in the 50's.
Just realized I forgot to post the link;
http://www.camaros.org/forum/index.php?topic=9770.msg71417#msg71417
btw, the Yankee Air Musuem at Willow Run was able to buy the final assembly part of the Willow Run plant.
Pretty cool opportunity.
http://www.mlive.com/business/ann-arbor/index.ssf/2014/11/nonprofit_award_yankee_air_mus.html
I thought The Citations were built at Tarrytown.
I know they were built in WR. I don't know if Tarrytown also built X-bodies.
We built the Citation "X"-body at Willow Run, Tarrytown, and Oklahoma City (each plant also built either the Buick Skylark,, Pontiac Phoenix, or Oldsmobile Omega). Tarrytown was the only plant that didn't have a full immersion/dip ELPO prime system - they just sprayed primer, and their "X"-cars rusted out first. :-(
We built the Citation "X"-body at Willow Run, Tarrytown, and Oklahoma City (each plant also built either the Buick Skylark,, Pontiac Phoenix, or Oldsmobile whateveritwas).
Oldsmobile Omega! ;)
(http://cdn.kaskus.com/images/2013/10/05/5883415_20131005113803.jpg)
Thanks - I edited my original post. :-)
I had a Phoenix ($450!) and a Citation. Great cars, IMO. And living in the north, FWD was a big benefit as was the room in a 4-door hatch.
I always wanted one of the X11 or Phoenix SX versions - they were fast in their day.
I bought an '81 Citation new and had Ziebart undercoating put on it. All that did was delay the inevitable; by the time I unloaded it in '87 even the hood had rust holes. Went from bad to worse as I then bought a used '85 Pontiac 6000 STE, the worst POS I ever owned. In two years I replaced the steering rack twice, fuel pump, oil pump, coil, ignition module, rear calipers. I never did fix the power antenna or power locks. Even the radio blew out. Had the A/C recharged several times. I'd like to think they have improved the quality but my BIL's 2003 Impala isn't much better.
GM chased away a lot of customers with the junk they built in those days.
Thankfully I went to the truck line in the 80's. I had a 4x4 84 Blazer with a 305. It was a turd but held up good except for the 700 transmission 110% failure rate.
I had a two-tone red/cream Citation and my wife had a metallic brown/black vinyl top Buick Skylark - both were 2.8 V-6's, never had any issues with either one; great winter cars.
My sister and her husband had a Citation X11 (red).. nice car (for the times).. When they needed a larger car, I considered buying it as a 'potential collector car' to keep, but I already had too many cars to *keep*.. :). I haven't seen one of those cars (or any Citations) in many years... they disappeared lots faster than first gen Camaros...
I think those were 200R4's at that point. My buddy had an '84 that launched the trans (by putting it in reverse) - it was a 200. Lotta problems with input shafts and front pumps -
I drove an '80 Citation for two years as a company vehicle - traded it in on an '83 Caprice when they came out. I always liked the Citation - black w/ grey interior. great service over two years of high mileage driving.
Regards -
I started my GM career at Willow Run in Transmission Engineering. It was a storied plant for sure, but not a great facility to work. It was pretty run down by the time I started working there in the mid-2000s. Just drove by the old facility on my way home from the airport. It's pretty much gone....
