Camaro Research Group Discussion => Restoration => Topic started by: DanZ10 on February 26, 2013, 08:07:52 PM
Ive searched the restoration catalogs for a key warning buzzer switch for a NON-tilt column. No one seems to carry this item any longer, but the switch is available for a tilt column. they are also available for a Corvette Tilt-tele option column. Does anyone know if any of the repo switches available today can be used in a '69 non-tilt Camaro column?
Thanks for your help in advance....
You need a P/N 7804414, which is available from HEARTBEAT CITY (http://www.heartbeatcitycamaro.com/store/product/24286/Camaro-NOS-Camaro-turn-signal-buzzer-1969-1981/) for a small fortune, or ZIP PRODUCTS (http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid=%7B65049964-D577-48B7-B039-C8C94F357A52%7D&gid=%7BC0EA5883-C07A-4E33-9A54-9F2716B8C1D8%7D&pname=69-79+Key+Warning+Buzzer+Switch&Referer=&Alias=&ptct=SGR-SR&CTitle=&) for $11.50. Zip is out of them right now, but they show they'll be shipping them again on March 13th.
DOC REBUILD (http://www.docrebuild.com/dr-r-web/ST-COL3.PDF) has them in stock for $21.75 (P/N 2187406 - #S on the page I linked you to) if you have to have it "right now".
If none of those sources work, then Landmark Chevrolet in Houston, TX shows they have an NOS one in stock for $18.30. Give them a call at 800-800-7278.
And yes, the Corvette part is exactly the same as the Camaro part. As a matter of fact, it was used by most GM cars and trucks well into the 80's!
