Camaro Research Group Discussion => Restoration => Topic started by: NoYenko on February 21, 2013, 08:03:36 PM
Title: Mirror mounting holes
Post by: NoYenko on February 21, 2013, 08:03:36 PM
I just noticed my left door has an extra screw hole for mounting the mirror I need to weld up. But there is another screw hole towards the back. Is this a factory hole used for a remote mirror or should we weld that up also. Did all doors have the large hole punched for a remote mirror? Thanks. George
Title: Re: Mirror mounting holes
Post by: Stingr69 on February 21, 2013, 10:49:01 PM
The remote mirror uses the same factory holes as the standard mirror. The non-reinforced holes are aftermarket mirror holes.
Post by: NoYenko on February 22, 2013, 02:46:03 PM
Stingr69,Thank you. So you are saying that rear hole should not be there, it is a countersunk hole that goes into the reinforcement like the 2 forward of the large hole.
Problem is I can't find a picture of a door with correct holes, I don't have a mirror bracket, and it will be painted soon.
Do you think this car could have had a remote mirror? Does anyone have a picture of original mirror holes? Thanks.  George.
Post by: vtfb68 on February 22, 2013, 03:38:50 PM
 NO,
I can't post a picture but I have a 68 with the same large hole. Deluxe interior? The gasket will cover the hole.
    VT
Post by: Stingr69 on February 22, 2013, 03:45:20 PM
The 2 holes you question in the photo are both aftermarket modifications. The 3 holes in the middle are factory.
You would need the interior door panels to tell if it had a remote mirror.  Even then, it is not proof. The interior panels could have come from another car. The adjustment knob hole (and bezel) would have been installed in the interior panel.  Custom interior uses a different bezel than the standard interior.
All of the door skins would have the same hole setup.
-Mark.
Post by: NoYenko on February 22, 2013, 04:58:00 PM
Mark,( All of the door skins would have the same hole setup.) Thanks guys that is the answers I needed. It is an original door & I think interior door panel without remote mirror hole. That's good I like the look of the standard mirrors. George
