Camaro Research Group Discussion => General Discussion => Topic started by: wisemanz28 on October 18, 2011, 04:53:22 PM
Is the floor pan and trans tunnel on a 1969 camaro the same as on a 1969/1970 nova ?
I believe so, but cant swear to it. Maybe this will get you some play.
Take some measurements, that should at the least eliminate it. I know the front sub frame is the same.
You do know AMD has a good reproduction available for around 4 bills.
I thought the center hump is different......
Kurt I was thinking the same thing, I also think the center hump is different.
Not the same.
