Camaro Research Group Discussion => Restoration => Topic started by: BowtieSweden on July 19, 2011, 06:41:11 PM
Title: Sealant between the heater box and the firewall?
Post by: BowtieSweden on July 19, 2011, 06:41:11 PM
What type of sealant is used between the heater box and the firewall?
Gus
Title: Re: Sealant between the heater box and the firewall?
Post by: JohnZ on July 20, 2011, 09:17:59 PM
Gus
None on the inside box ( the dash mat becomes the gasket between the inner box and the firewall). The engine side blower housing had a bead of neoprene or vinyl plastisol sealer applied in its groove before it was attached to the firewall.
Post by: BowtieSweden on July 21, 2011, 04:10:19 PM
That was where I meant, in the engine compartment.
Any suggestions for products that are available today?
 / Gus
Post by: firstgenaddict on July 22, 2011, 09:08:44 PM
Almost any Black Body Sealer in a tube applied using a caulking gun. Ask at the Local Paint suppliers
Post by: 68rs327conv on July 23, 2011, 01:23:49 AM
I planned on using the 3m strip caulk when I put mine back on
