Camaro Research Group Discussion => General Discussion => Topic started by: wisemanz28 on April 24, 2011, 05:20:53 PM
Title: 1969 z28 starter
Post by: wisemanz28 on April 24, 2011, 05:20:53 PM
Is a 1969 Z28 starter supposed to have a cast iron nose or a aluminum nose?
Does anyone has a pic of one , I bought one from a guy and it won't bolt up to my Z28 for some reason.
Title: Re: 1969 z28 starter
Post by: bertfam on April 24, 2011, 05:24:00 PM
1108367 with an aluminum nose.
Post by: Stingr69 on April 25, 2011, 12:57:56 AM
You may have the wrong starter OR the wrong bellhousing-clutch-flywheel setup. The bolt holes are supposed to be in line, not staggered. Aluminum nose is typical. The number stamped on the steel starter case does not need to match anything.
What starter did you pull out of there before? What are the last 3 digits cast into the bellhousing? "403"? or "621"? or something else?
-Mark.
Post by: wisemanz28 on April 27, 2011, 02:11:56 AM
Got it figured out guys , wrong flywheel
