Camaro Research Group Discussion => Decoding/Numbers => Topic started by: stovebolt on January 18, 2011, 01:30:37 PM
Title: Alternator Pulley P/N
Post by: stovebolt on January 18, 2011, 01:30:37 PM
I'm looking for the part number for the double-groove pulley that goes on alternator 1100813. The AIM doesn't supply the number. Thanks, Joe.
Title: Re: Alternator Pulley P/N
Post by: bertfam on January 18, 2011, 02:42:08 PM
According to the PULLEY LIST (http://www.camaros.org/pdf/pulleys-PN-2007-02-01.pdf), the 68 Camaro L6 cars got the 1969433 pulley.
Post by: stovebolt on January 18, 2011, 11:37:19 PM
I did look at the pulley list. I read it as ALL L6's or ALL K76's. But not all L6's required a double groove pulley. Further enlightenment would be appreciated.
Post by: bertfam on January 19, 2011, 04:31:10 AM
I'm not home until Saturday morning, so I can't do any further research. If someone else doesn't chime in before then, I'll see what I can dig up.
Post by: JohnZ on January 19, 2011, 06:39:04 PM
If you look at the belt routing charts in the '68 A.I.M. in UPC 6, sheets A8 and A9, the only L-6's that don't use the double-groove pulley (and don't use the 813 alternator, which came with the double-groove pulley already on it) are the base-engine automatic with no options, and the base-engine automatic with A/C.
Post by: stovebolt on January 20, 2011, 01:08:16 PM
Thanks Ed and John. It looks like 1969433 is the correct one. Joe.
