Camaro Research Group Discussion => General Discussion => Topic started by: grimkeeper on September 13, 2010, 02:34:04 AM
Title: 1969 Camaro Z28 - good deal? What to look for?
Post by: grimkeeper on September 13, 2010, 02:34:04 AM
Hi all...I'm new to this forum. I posted this thread on another forum and someone suggested posting here. They said you guys are the 1st gen experts!
I am considering buying a 1969 Camaro Z28, but not sure on how to determine what a good price is and what to ask or look for? Here are the details I have about the car I am looking at...any input on whether this is a reasonable deal would be appreciated (sorry for the long first post):
1969 Camaro Z/28 302
- 4speed
- 61,000Kms
- CE warranty replacement block, numbers matching intake, heads, carb, Muncie M21, 12-bolt, too many parts to list. Lots of correct spare parts. 10-year old restoration. American car.
Asking price: $31,000 (Canadian)
Is this a reasonable price and what should I be looking for when I go to see the car? Below are the pictures and some additional detailed info the seller has provided:
VIN# 124379N70284702****
12437 - 8-cylinder Sport Coupe
9 - Model Year - 1969
N - Assembly Plant - Norwood
Trim Plate:
ST69 (1969) 12437 (V-8 Coupe) NOR1 (Norwood)
TR 711 (Standard Interior) 76 (Daytona Yellow)
10D (October - 4th week of month) X33 (Special Performance Equipment - Z28) D80 (Air
Spoiler Equipment)
Alternator: 1100837 37A - all original brackets
- Date Code: 9F17(’69 June 17)
Bell Housing (spare): 3858403 & Plate Cover: 354497
Brake Booster: 9204
Block Casting#: 3970010
Camshaft (spare): Casting #: 3849347
Carburetor: On car - Holley: 3923289-DZ4053 Date Code: 921(’69 Feb)
Spare - Holley: 3923289-DZ4053 Date Code: 952(’69 May)
Crankshaft (spare): 3941178
Cylinder Heads (on car): 3973370
- Date Codes: D230 (April 23/70) & E10 (May 1/70)
Cylinder Heads (spare): 3927186
- Date Codes: K308 (Nov 30/68) & A189(Jan 18/69)
Distributor: 1111480
Dip-Stick: - original green end
Fan 7-Blade: 3947772
- Date Code: H69(Aug ’69)
Fan Shroud: 3938615
Housing #: 3899621, Side Cover #: 3952648, Rear Cover #: 3857584
Hurst Shifter: 3925660 – original handle and ball
Intake Manifold: 3932472
Master Cylinder: 5468309 (‘US’ stamp)
Pulleys: Waterpump: 3932456DV
Crankshaft: 3956668CG
Alternator: 1970831 (deep groove)
Radiator (spare): Tag ID = IUH (Z/28), CB (1969 302)
Rear Axle Casting #: 3969641NF
Stamp: BM1016G2
Starter (spare): 1108367
- Date Code: 9E15(’69 May 15)
Thermostat Housing: 3877660 – aluminum
Timing Chain Cover: - correct welded tab, 4 in. from crankshaft seal hole centre
Tire jack, stand, wrench: original
Transmission Casting #: 3925661
Valve Covers (on car): 14025553 L.H, 14025554 R.H
Valve Covers (spare): Correct – 474207 L.H, 474208 R.H
Water Pump: 3953692
- Date Code: F59(May 5 ’69)
All hoses, clamps, sparkplug wire looms are correct.
Title: Re: 1969 Camaro Z28 - good deal? What to look for?
Post by: tom on September 13, 2010, 01:49:05 PM
If the car was originaly sold in Canada, you can verify the original options thru GM Canada. They have records by vin number. You can start here: http://www.camaros.org/forum/index.php?topic=6860.0
Post by: KurtS on September 13, 2010, 02:20:06 PM
I've known about the car for years and wondered about the axle ratio.
I wonder no more - fake tag. Probably not a real Z with that axle, probably was an SS.
VIN is 124379N702847.
Post by: jmcbeth on September 13, 2010, 08:37:17 PM
Grimkeeper,
As you saw in Kurt's post above, you definitely came to the right place. These guys are very, very good. If you get to the place where you  are serious about buying a '69 Z, I would recommend contacting Jerry MacNeish. Jerry will inspect the car for authenticity for a very reasonable cost. I've used him multiple times in the past and he has saved my bacon.
Best of luck in your search!
John
Post by: grimkeeper on September 14, 2010, 02:09:29 AM
Thanks John.  I will keep that name in mind if I get to the point of seriously considering a purchase.  It's too bad about this one it looked like a pretty clean car.
Post by: jmcbeth on September 14, 2010, 12:25:40 PM
Fraud is rampant on these cars. It was very smart to ask for advice. Have you purchased Jerry's book? See http://www.z28camaro.com/publications.html. Invaluable resource for what you are seeking. If you get the book, you will see that there are several things wrong on the list you provided above.
