Camaro Research Group Discussion => Mild Modifications => Topic started by: Da67Kid on April 08, 2009, 12:50:57 AM
Hi all I am Guss! Hi Guss !I suffer from Big Cam No VACUUM (LOL)
What are some of the electric vacuum setup people are using and with and info and pics would be good. i seen one not sure of make all billet and like a small box about $450 I was looking for a low dollar cure There are so many vac pumps out there I though I would ask. Thanks
Jeg's sells a nice little vacuum canister that will let you use your power brakes and doesn't require a pump. Might be worth a look. Good luck!
<<Jeg's sells a nice little vacuum canister that will let you use your power brakes and doesn't require a pump.>>
I used one of those on my tube-frame Grand Sport replica instead of buying a pump, and it worked out fine.
I do not make any vacuum with the cam i run so I can not make any in a can from them . I am looking for a 12 volt one Other then the high dollar ones i keep finding. Thanks
You might not make any vacuum at idle but you will make vacuum at higher RPMs and on deceleration. Install a can with a check valve beteen the can and the manifold any you'll be fine.
I have a big inch SB in my car with a roller cam with 4 wheel disc brakes. I had to put an electric pump in . It works well but the down side is when you put your foot on the brake you can hear that pump kick on and work and my car is loud and completley DynaMat'd . So if you can make it work with Mark's sugesstion then that would be great otherwise you can get this pump at Summit . I mounted it front drivers side and when looking straight on to the motor you can't even see it .
(http://img.photobucket.com/albums/v600/ChevyThunder/Hugger%20Orange%20X33/VintAir/th_dbf29432.jpg) (http://img.photobucket.com/albums/v600/ChevyThunder/Hugger%20Orange%20X33/VintAir/dbf29432.jpg)
(http://img.photobucket.com/albums/v600/ChevyThunder/Hugger%20Orange%20X33/VintAir/th_e0ffd43d.jpg) (http://img.photobucket.com/albums/v600/ChevyThunder/Hugger%20Orange%20X33/VintAir/e0ffd43d.jpg)
(http://img.photobucket.com/albums/v600/ChevyThunder/Hugger%20Orange%20X33/VintAir/th_0b78f8f5.jpg) (http://img.photobucket.com/albums/v600/ChevyThunder/Hugger%20Orange%20X33/VintAir/0b78f8f5.jpg)
(http://img.photobucket.com/albums/v600/ChevyThunder/Hugger%20Orange%20X33/VintAir/th_bee8d5b3.jpg) (http://img.photobucket.com/albums/v600/ChevyThunder/Hugger%20Orange%20X33/VintAir/bee8d5b3.jpg)
I did try the Can but does not work I also have a small aftermarket brake booster 4 wheel disc set up, will have to do a electric pump I guess.
John that car is awesome. Do you still have it?
Nope, sold it in 1998 - needed the garage space for another project.
