Camaro Research Group Discussion => Restoration => Topic started by: crobjones2 on January 24, 2008, 02:10:01 AM
What are the differences between imported vs. domestic sheetmetal panels?
For judging would it be better to repair damaged original sheetmetal or replace it?
Chris
Usually original GM parts are a better solution if you can get them.
Repro stuff is made from thinner gage steel which has a tendency to not hold its shape within tolerances once the stamping process is finished. GM used certain gage steels for a reason. Pacific rim repro stuff is made from thinner material to cut corners, save money, which usually translates into more time spent on fit and alignment of body panels.
Original pieces may be more costly but could easily save you time by aligning properly without having to evoke the old adage, "Beat to fit, paint to match".
Chris
Original patch panels are best because I bought a repro trunk pan to repair the original pan and the depressions do not line up. Poor stamping quality.
