Camaro Research Group Discussion => Maintenance => Topic started by: passline7741 on January 16, 2008, 11:45:24 AM
Title: fuel gauge problem
Post by: passline7741 on January 16, 2008, 11:45:24 AM
My fuel gauge only reads  only 1/8 full since I replaced my tank and sending unit.It goes down from the their as fuel is used and tank is close to full of fuel.What do I need to do to fix the problem? Thanks,Bob
Title: Re: fuel gauge problem
Post by: basecoupe#79 on January 18, 2008, 12:13:58 PM
Check your ground wire.
Post by: FBODY on February 05, 2008, 01:05:55 AM
Hi passline7741,
I tried two new repro sending units from Classic Industries, they were made by dii, both did not work properly. They were shouwing 3/4 when the tank was full, and showing Empty when I still had a 1/4 of a tank.
I installed a Spectra Premium Sending Unit P/N FG104C (3/8 Single Line), from NAPA, this spring and it works fine.
Good Luck, Daniel.
