Camaro Research Group Discussion => Originality => Topic started by: Rustynut on September 07, 2023, 01:40:12 AM
Which Rear end gear ratio was available on 1968 Camaro SS 350 with borg warner 3 speed and 12 bolt?
Please and thanks
Any chance 4:10 gears were an option?
I don't see 4:10 available as an option on the powertrain chart.
3.31 std, 3.07 econ, 3.55 perf, and 3.73 spec.
I have never seen one with a 3 speed and 4.10 gears. Possible with M20.
Do you have one? How does the axle assembly date compare with the car assembly date? Have an docs?
Yes I do have one, but haven't checked any dates yet. I guess that would be a logical next step, thanks
Please check the front edge of the passenger side axle tube for the assembly date and the center section for the casting date.
http://www.camaros.org/drivetrain.shtml#axle
Also if possible post details of the engine and transmission.
You can send me a direct pm if you want.
Ratios available: http://www.camaros.org/suspen.shtml#axles
