Camaro Research Group Discussion => Maintenance => Topic started by: JGraft on November 06, 2022, 07:21:38 PM
Has anyone been able to remove and reinstall a 621 bell housing in a 1968 camaro without removing the engine? From what I've read it seems it can be done but wanted to confirm with the experts. I plan to replace transmission, clutch, pressure plate, throwout bearing, pilot bushing, and flywheel as well, so I need to be able to get the bell housing out/into the vehicle.
Yes, not a problem. I've done it MANY times!
Yes, easily.
The engine does not need to be removed for any transmission/related parts removal….as stated above.
Thankyou experts for responding, should make this job much easier! :)
I would check your bellhousing alignment. Parallel and concentric. I stock all the shims and dial indicators to do so.
VERY IMPORTANT!!!!!!
