Camaro Research Group Discussion => Decoding/Numbers => Topic started by: gbowman on May 13, 2021, 09:15:08 PM
Title: 69 Cowl Tag
Post by: gbowman on May 13, 2021, 09:15:08 PM
Does this tag look suspicious to anyone or am I missing something? I've never seen NBR for Norwood.
Title: Re: 69 Cowl Tag
Post by: bertfam on May 13, 2021, 09:17:13 PM
You mean other than the pop rivets holding it on?! What's the VIN? The trim tag's been off the car and may not belong.
Post by: gbowman on May 13, 2021, 11:09:23 PM
The pop rivets were the first indication for me. But I'm not familiar with NBR on a 69 cowl tag. I've asked for the VIN. Thanks.
Post by: gbowman on May 13, 2021, 11:12:53 PM
VIN:124379N506128
Post by: x66 714 on May 13, 2021, 11:14:12 PM
You can do a search on NBR. Several threads....Joe
Post by: MO on May 14, 2021, 12:37:59 AM
Wow!
Post by: bertfam on May 14, 2021, 01:06:53 AM
Looks okay other than the rivets. Should be a 09A tag but the rivets cover most of the date!
Post by: bcmiller on May 14, 2021, 02:13:45 PM
NBR is a known error for that time period.
Post by: gbowman on May 14, 2021, 09:45:30 PM
Yes, I've since found that out after Joe pointed me in the right direction, thanks Joe! The owner/seller said they have had the car 15 years and it was like that when they acquired it, but it has definitely been off the car at some point I believe. There are traces of yellow paint in the trunk area, but I still have no way of knowing if the cowl tag is original to the car. Thanks for all the comments.
