Camaro Research Group Discussion => Originality => Topic started by: hdptsr on March 07, 2021, 06:10:00 AM
What is the length of foam on 1969 Camaro AC hose, the hose from compressor to the Evaporator? The protective foam as it goes over the alternator? Do they sell a reproduction?
Someone on here found a replacement foam from I believe a Mustang parts supplier - do a search under Power Steering hose - it also has foam over the top for a short length.
There are 2 pieces of foam on the main hose from the manifold to the POA valve. Mine measure 4-3/4 but they were most likely 5". From the bell on the manifold it's 18" to the first one. There is 6" between the 2. I purchased part number 15190971 GM from Ebay. Not possitive if it will work but it was cheap. Like 5 bucks. I can take pictures if you need....Joe
Would something like this work for the accumulator hose insulation?
Aeroflex 3/4 pipe insulation
https://www.ebay.com/itm/Aeroflex-212-Ac11838-3-4-X-6-Ft-Pipe-Insulation-3-8-Wall/383968963855?hash=item5966556d0f:g:Jx4AAOSwctVgMWcT
Any pictures of original would be great!
Thanks Joe
Maybe but it looks too thick. The hose measure 1.66 diameter. Here's some pictures...Joe
Maybe check a place like McMaster Carr to see if they have thinner wall insulation available, in a suitable foam material.
I am going to order this and try it, I will let you know how it turns out.
https://www.ebay.com/itm/1M-Sponge-Foam-Thermal-Insulation-Pipe-Handle-Bars-Rubber-Tube-Fitness-Equipment/263149203484?hash=item3d44ea301c:g:ka4AAOSw2J1ZlpeS&var=562147240709
