Camaro Research Group Discussion => Maintenance => Topic started by: joesauer on March 19, 2020, 08:12:42 PM
Under a shelter in place order, so plenty to time to get an early start on springtime projects. Decided to replace my 68' standard door panels & clean/lube window & door gears/mechanisms. 50 plus years of gunk. Any suggestions for the best grease/gunk removal product? Any recommendations on the best lubricants to use?
I've used ZEP Purple cleaner to soak and remove the gunk, then used Mobile 1 synthetic grease to re-lube.
I've seen Gunk engine cleaner used successfully too to clean the parts. This is with all the components out of the door of course.
I use a “grease stick” . A stiff waxy substance that resembles beeswax
The grease stick works great on tracks, mobile 1 injected with a rubber tip in the transmissions (gearbox)
