Camaro Research Group Discussion => Restoration => Topic started by: Danzo on March 25, 2018, 01:06:02 PM
Has anyone tried the "new" drip rail molding set?
Thanks.
I've used 3 sets. Two from D&R, one from Ground Up. All were the high quality, more expensive, GM Restoration ones. Fit and finish was fine. Some vendors off both the low and high quality type.
Like with a lot of parts, the less expensive versions can end up costing you more (more time involved to get it to fit right). :)
