Camaro Research Group Discussion => Decoding/Numbers => Topic started by: stovebolt on October 12, 2016, 11:42:18 AM
Title: Delco Fuel Pump
Post by: stovebolt on October 12, 2016, 11:42:18 AM
Could someone help decode this fuel pump's date? 297N. It's for a 1968 L6. Thanks.
Title: Re: Delco Fuel Pump
Post by: ko-lek-tor on October 12, 2016, 12:04:54 PM
replacement pump October of 1974 (1975 model year)
Post by: stovebolt on October 12, 2016, 12:11:54 PM
Can you break down the code so I can figure out others? Thanks.
Post by: ko-lek-tor on October 12, 2016, 12:21:35 PM
Study this http://nastyz28.com/forum/threads/ac-fuel-pump-date-code-research-data.207770/
GM in the 60s had a 2 letter code where the first letter was the month A=Jan,B=Feb and so forth and the second letter represented the year, H=68, I=69,J=70
Starting in 71 the Julian date replaced the 2 letter. So 1=jan1st & 365= Dec 31st and all points in between. The Letter after the number, the year, still followed in order of previous, J=70, K=71...N=1974
Your pump is 297=297th day of the year (end of October) and N=74
Post by: stovebolt on October 12, 2016, 01:44:24 PM
Thanks very much.
