Camaro Research Group Discussion => Maintenance => Topic started by: camaroman1969 on June 05, 2016, 12:49:05 AM
Title: Noisy tranny/clutch????
Post by: camaroman1969 on June 05, 2016, 12:49:05 AM
Hi everyone!!!  I just re-built my M-22 trans and is coupled with a newer Center Force Dual Friction clutch.  Put it all back together, and it making this "rubbing" or "chatter", squeaky noises.  When driving, it appears to stop for a moment.  Then it starts again.  When I take it out of gear and coast, it is still making noise.  Where do I look??  Does tranny have to be pulled again??  If anyone out there has had similar problem, feel free to chime in and advise the best remedy for this.  Hope to hear from somebody.  Thanks all......
Title: Re: Noisy tranny/clutch????
Post by: bcmiller on June 05, 2016, 01:55:05 AM
Do you install the correct new throw out bearing for the new clutch/pressure plate?
Post by: camaroman1969 on June 06, 2016, 01:09:39 AM
Yes, to my knowledge.  I'll ask my car guy for sure.  Is there anything else that could be creating this noise??  Thanks for your advise.  Appreciate it.
Post by: L78racer on June 06, 2016, 02:23:05 PM
also check for the clutch dust shield hitting crank or something in that area.
