Camaro Research Group Discussion => Restoration => Topic started by: Mike S on January 15, 2016, 02:47:15 PM
Title: Anyone crush soild rivets?
Post by: Mike S on January 15, 2016, 02:47:15 PM
 Has anyone rebuilt their steering rag joints using solid rivets as supplied in kits? I have a 20 ton press at home and was wondering if I could successfully crush the solid rivet supplied in the rebuilding kits and if any special blocks are required. I want to keep the factory look instead of using the other kit that uses nuts in place of rivets.
Thank You,
Title: Re: Anyone crush soild rivets?
Post by: HawkX66 on January 15, 2016, 03:31:51 PM
Thank You,
I'd love to know the same thing. I still have my original, but I can't run it because the flex part is ripped. I'd love to rebuild it.
Post by: TODD on January 15, 2016, 07:49:17 PM
Got a pic of what it looks like? Rivets usually need expanded quickly to prevent the material form work hardening. So a rivet gun or a pneumatic rivet squeeze work best that is for aluminum and steel rivets.
Post by: HawkX66 on January 15, 2016, 08:36:49 PM
Bad pics of mine, but here's a pic of the front and one of the back.
(http://i1164.photobucket.com/albums/q573/SgtHawkUSMC/69%20Camaro%20SS396%20L34/69%20Subframe/20141228_160123.jpg) (http://s1164.photobucket.com/user/SgtHawkUSMC/media/69%20Camaro%20SS396%20L34/69%20Subframe/20141228_160123.jpg.html)
(http://i1164.photobucket.com/albums/q573/SgtHawkUSMC/69%20Camaro%20SS396%20L34/69%20Subframe/IMG_20150705_102803.jpg) (http://s1164.photobucket.com/user/SgtHawkUSMC/media/69%20Camaro%20SS396%20L34/69%20Subframe/IMG_20150705_102803.jpg.html)
Post by: TODD on January 16, 2016, 01:36:35 PM
You mean these rivets?
(http://i22.photobucket.com/albums/b309/ToddZ/874481700_o1.jpg) these are at very large 3/8" inch or so?
I would guess they used a large pneumatic squeeze for those and the rivet sets are probably made specific for those configuration. They have a large stem on the opposite side.
Post by: TODD on January 16, 2016, 02:12:32 PM
Just my opinion:
These are a safety item I wouldn't take it on. Not unless I wanted to buy some expensive tooling to properly install those types of rivets, you can't really call those rivets, it's an unset stem on a safety tab of some sort.
I understand the desire to do that as an NOS rag joint is $500 that's crazy?
Post by: HawkX66 on January 17, 2016, 01:26:21 AM
Here's a couple better shots of my original. IMO, there's no reason that these can't be rebuilt. I'd love to say it could be done with our 20 ton presses, but I'm not sure. It's not exactly an intricate design.
(http://i1164.photobucket.com/albums/q573/SgtHawkUSMC/IMG_20160116_145742.jpg) (http://s1164.photobucket.com/user/SgtHawkUSMC/media/IMG_20160116_145742.jpg.html)
(http://i1164.photobucket.com/albums/q573/SgtHawkUSMC/IMG_20160116_145639.jpg) (http://s1164.photobucket.com/user/SgtHawkUSMC/media/IMG_20160116_145639.jpg.html)
(http://i1164.photobucket.com/albums/q573/SgtHawkUSMC/IMG_20160116_145700.jpg) (http://s1164.photobucket.com/user/SgtHawkUSMC/media/IMG_20160116_145700.jpg.html)
