Camaro Research Group Discussion => Restoration => Topic started by: Fanthomgreen69 on December 18, 2015, 02:15:26 PM
Title: 1969 console oil presure gauge
Post by: Fanthomgreen69 on December 18, 2015, 02:15:26 PM
Have a 69 Z/28 with console gauges. When the engine is turned off the oil pressure gauge only returns to 20 lbs. Is there a way to make it return to zero without tearing it up?  I have a repo gauge but would rather use the original if possible.
Charles
Title: Re: 1969 console oil presure gauge
Post by: 69Z28-RS on December 18, 2015, 02:54:06 PM
It's a mechanical gauge, meaning that pressurized fluid (oil) actually flows into the gauge when the engine is running.  Perhaps a bit of trash in the oil got into the gauge and is affecting the display (assuming that the gauge is registering 20 when the pressure is actually zero??  I've made mechanical gauges work before by cleaning them inside  *using alcohol or something similar*, then regulated air pressure into the gauge to test it as various pressures.  If you have an air compressor with regulator, simply adjust the pressure to a low pressure and hold the air pressure into the gauge (an air blower with rubber outlet is good for that)...   vary the Air Comp pressure over the range of the gauge and test it's accuracy.  There is very little that can really damage one of these mechanical gauges.
Post by: Fanthomgreen69 on December 18, 2015, 03:41:01 PM
Thx for the input. Should I also try a little suction on the opening on the back of the gauge?
