Camaro Research Group Discussion => General Discussion => Topic started by: camaroman1969 on October 25, 2015, 01:28:22 AM
Hey Guys..........Has anyone seen a Camaro big block, with a "torque strap bracket" bolted to the engine??? Are they available?? Any input will be helpful. Thanks everyone. Don
Those were recall items, original motor mounts were prone to breakage causing weired gas pedal fluctuations and accidents.
there should be threads on this site, use search.
VT
They were a bandaid repair due to non-interlocking motor mounts. When the mounts broke, throttle linkages could jam.
Biggest recall ever at the time.
Also caused a general design change to cable linkages.
Here's one............http://www.camaros.org/forum/index.php?topic=2455.0
Use advanced search.....
