Camaro Research Group Discussion => General Discussion => Topic started by: miket1 on September 29, 2015, 02:51:06 PM
I removed the front clip on my 69 Z28 to do engine bay detailing, is it a big problem to bolt on the inner fender first, then mount the fender to it, or should I install as a complete assembly.
I've heard of people managing to get the outer fender installed after first installing the inner fender, but when I did mine a few years ago, I installed the inner fenders and outer fenders as assemblies, loosely bolted in place first, then mated the lower valence and upper header panel - got the gaps where I wanted them and snugged everything down.
Due to the way they go togetheer and my very limited experience working with sheet metal, it seemed to make a lot of sense at the time to install the inner and outer fenders as an assembly. Worked out well.
Good luck
Richard
Good luck
Richard
That's how the car was built originally.
OK , which ever is easiest & best is what I am looking for.
