Camaro Research Group Discussion => General Discussion => Topic started by: dannystarr on September 28, 2015, 06:33:34 PM
Title: Holley Accelerator Pump Tool
Post by: dannystarr on September 28, 2015, 06:33:34 PM
Where can I get that special tip tool to remove the accelerator pump screws on my 4150 Holley carb? I looked everywhere online. Anybody have a part number. I could switch it out to a Phillip's head, but trying to keep it as stock...Can't find it on Amazon, eBay, or even a google search... WTF... D
Title: Re: Holley Accelerator Pump Tool
Post by: cook_dw on September 28, 2015, 06:46:33 PM
Its called a clutch head screwdriver bit.
http://www.amazon.com/STANLEY-Clutch-Head-Bit-Screwdriver/dp/B005SG1QU4 (http://www.amazon.com/STANLEY-Clutch-Head-Bit-Screwdriver/dp/B005SG1QU4)
http://www.amazon.com/Piece-Clutch-Head-Screw-Driver/dp/B007ZS38PO (http://www.amazon.com/Piece-Clutch-Head-Screw-Driver/dp/B007ZS38PO)
Or take a flat head and cut it down to fit the slots.  Done it both ways.
Post by: firstgenaddict on September 29, 2015, 07:01:51 PM
The first time I encountered them, I ground and filed an old phillips head that was worn until it fit. It works in a pinch, just ensure the tool will seat and doesn't rock back and forth.
Post by: little_hoss on September 29, 2015, 08:22:51 PM
Got mine from Sears about a year ago in one of their bit driver sets because I ran into the exact same problem. Came with a screwdriver handle and I think around 15 different bits, (torx, Phillips, clutch, flathead, etc...), that inserted into the handle. Pretty cheap to if I recall.
Post by: dannystarr on September 29, 2015, 08:30:42 PM
I ordered the one from Amazon. I have SO many bits. I gotta take a look thru them all someday and see, as I might have them. I have MANY security bit tips also. But for now, got a small leak to take care of...D
Post by: KurtS on October 01, 2015, 05:10:24 AM
I was too slow. Just got a clutch bit with a set today. Don't need it and would have sent it to you....
Post by: dannystarr on October 01, 2015, 06:07:43 AM
I appreciate that Kurt.  8) 8) Save it for another member someday?... D
