1969 Z/28 FLAT HOOD car. Does the 298 coil for a flat hood Z/28 use the same coil bracket as the 293 coil? Does the 298 coil bracket lay the coil back a little farther towards the firewall? Thanks, Sam
The coil itself is the same for both applications, but the coil and bracket were received at the plant as an assembly; the one with the laid-back bracket was used with the ZL2 hood, for clearance to the air cleaner base.
Thanks John. Sam
