Author Topic: Water pump gaskets 69z  (Read 2481 times)
john302
« on: January 05, 2021, 02:59:40 AM »
Here is a good question. Are the waterpump gaskets the same left and right?one side has three holes and the other side has four. I usually trim the gasket for the side side with the three holes.Only owned one car with the true original waterpump never removed and didnt  looked at it . Anyone have a car with the waterpump never removed?
ALLZS
Re: Water pump gaskets 69z
« Reply #1 on: January 05, 2021, 01:49:08 PM »
I just removed a original water pump   never removed from a 69 nova 307 and it had   the 2 hole gaskets on both sides
rszmjt
« Reply #2 on: January 06, 2021, 02:04:03 PM »
FWIW - I don’t know if 69 is different from 1970 BUT-  I have a unmolested 6,000 mile 1970 Z28 LT1 motor , that has never been apart ( except for taking valve covers off ) , and it has a 4 hole gasket on passenger side and the 3 hole gasket on drivers side. I had old NOS GM gasket kit before and it had 1- 4 hole gasket and 1 -3 hole gasket.
I was under the impression that the 4 hole gskts were generic type that were supplied by rebuilders?
I’ve been trimming the extra hole off for years in all our restorations.
Maybe James or Kurt will comment?
Hope this helps.
« Reply #3 on: January 06, 2021, 10:59:59 PM »
I have bought a few NOS water pumps - 608s, 609s and they had black 2 (bolt) hole gaskets.
john302
« Reply #4 on: January 08, 2021, 11:50:44 PM »
I have been trimming them for years also . Just trying to figure out what is true assembly line . thanks everyone
Jerry@CHP
« Reply #5 on: January 11, 2021, 03:48:49 AM »
Two hole gaskets were factory installed so cutting off the extended gasket hole is the correct way to go.
Jerry
john302
« Reply #6 on: January 16, 2021, 03:18:46 PM »
thanks for the info everyone !
