Camaro Research Group Discussion => Originality => Topic started by: mgerg11 on February 13, 2024, 03:31:50 PM
Why do some power steering boxes have 3 ears verses 4 ears for mounting to the frame? Is there one that is only correct for a 69 Z or is both acceptable? Thanks!
CRG information on power steering boxes:
http://www.camaros.org/suspen.shtml#steer
I saw that but it doesn’t clarify for power steering boxes.
According to this article in Hemmings, the power steering boxes used in 1969 Camaros used 4 bolts:
https://www.hemmings.com/stories/article/quick-ratio-steering-boxes
The table at the end was poorly constructed. It says 3-hole, which is also my recollection.
1967-'76 Camaro, Firebird
1970-'76 Monte Carlo/Malibu
1964-'76 Chevelle
1977-'79 12.7:1 quick-ratio gearbox
Line Thread Size: 11/16 x 18 and 5/8 x 18
Number of Mounting Holes: 3, (missing leg H-pattern)
Input Shaft Diameter: ¾-inch
Output Shaft Diameter: 1 ¼-inch
Number of Turns Lock to Lock: 2 ½- 3
