Camaro Research Group Discussion => Decoding/Numbers => Topic started by: opelitis1 on October 10, 2008, 07:54:56 PM
Just pulled this from a 283ci 3789935 casting engine... Cam is numbered towards rear maybe 3 - 4 lobes up with these numbers 373 2798.. Any ideas what it came from and figures re. duration and lift..
Thank You!!! T.
1957-1966 283 and 327 application. Used in a number of low to medium horse power ratings.
Lift is .398 and duration is 300
Thanks Bert!!! Was hopin' it was a more git up 'n go cam like the ole solid lifter 097 unit
from way way back with .398 lift on both sides. T.
That was the standard hydraulic-lifter cam for all '57-'66 base engine applications.
