Author Topic: Preservation of a 68 Camaro  (Read 62115 times)
Re: Preservation of a 68 Camaro
« Reply #420 on: October 23, 2023, 05:01:14 PM »
Photos 858 - 860 - Drivers rear wheel well.  Still more cleaning to be done but you hopefully can see the progress.
« Reply #421 on: October 23, 2023, 05:02:37 PM »
Photos 861 - 863 - Drvr cont.
« Reply #422 on: October 23, 2023, 05:07:19 PM »
Photos 864 - 866 - Passenger side rear wheel well
« Reply #423 on: October 23, 2023, 05:10:43 PM »
Photos 867 - 869- Trunk floor
« Reply #424 on: October 23, 2023, 05:14:03 PM »
Photos 870 - 872 - Reinstalling hardware and brackets
« Reply #425 on: October 23, 2023, 05:14:43 PM »
Photo 873 - Reinstalling cont.
169INDY
« Reply #426 on: October 23, 2023, 06:11:01 PM »
One MUST realize that this Rear (Bottom) section is Very difficult to accomplish these results, This represents a TON of Work. My Neck and Back are aching just looking at this.
Super Hard. Manually with these results.
Can you share how or what you plan to do with the Surface Oxidized sheet metal, Coat with Rpm, Oil, Boeshield T9 ?
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
« Reply #427 on: October 23, 2023, 07:09:01 PM »
Thanks Jim.  Yes I will coat the areas of surface rust.  I initially thought I would setup the wash station of evapo and get all the areas completely clean but after cleaning I didn't feel like it so I plan to coat the areas with Rust Veto most likely.  In the areas where there is undercoating I will do RPM.  I may do all RPM just depends on how I feel once I start the process.  I will update on what I end up using when the time comes.  I still have to touch up some areas after stepping away from it for a few days and seeing these photos I see areas I am not happy with so I will knock those out next (also something) and then go to the protection aspect.  I might snag some Beoshield and give that a try also.  Something I have yet to use.
« Reply #428 on: October 25, 2023, 12:42:26 PM »
It may not look like it but I am more satisfied with the quarter wells.  Note the quarters well lips had been rolled at some point.
Photos 874 - 875 - Driver qtr well
« Last Edit: October 25, 2023, 02:11:21 PM by cook_dw »
« Reply #429 on: October 25, 2023, 12:43:05 PM »
Photos 876 - 877 - Drvr cont.
« Reply #430 on: October 25, 2023, 12:43:52 PM »
Photos 878 - 880 - Pass qtr well
RPOLS3
  • 815-985-3664
« Reply #431 on: October 30, 2023, 12:38:00 PM »
Outstanding!  It has been a few months since I checked in, lots of amazing progress.  Thank you for sharing.
Jake Dykstra
FRANKTHECRANK
« Reply #432 on: January 22, 2024, 01:38:10 PM »
It's been almost 3 months since any updates. This thread is addicting, and I need a fix...lol.
« Reply #433 on: January 22, 2024, 02:47:27 PM »
More like making me feel guilty.
