68 rs ss am fm multiplex radio
fsc66:
Mike, I'm sure the multiplex box is the same but it mounts centered in the console door from left to right, whereas the 68 Camaro mount is off-set. Which measurement are you thinking will help you?
lilfighta:
Hi Paul if you look close at the picture of cover that i posted you will see 2 lines one on bottom of box and one on top built into the cover .
Then if you look at the hinge side you might be able to see the bracket. The box probably sits center of the 3
things. So if i can get the size of the square box which would probably be around 31/2 to 4" square. Not sure though
and the distance between the top of box and side of box to center of volume control button which looks to be around 3/4".Then I probably could center the box correctly. I wish i can find old garbage one that doesnt work so i dont have to bother people and get measurement .
Thx Paul
lilfighta:
This is what I need
Navigation
[0] Message Index
[*] Previous page
