Camaro Research Group Discussion => General Discussion => Topic started by: x66 714 on June 16, 2021, 08:15:35 PM
Owning a late 1969 Camaro you relize several things don't fit into "normal".
Aquired a 227 pitman arm from another box today. The box I took the arm from is dated 121 9 & the socket size was 1-5/16
My box is dated 011839 & the socket size is 1-9/32
Anybody else run into this?
Thank you, Hoe
Mine (01C ‘69 RS auto) was 1-5/16”. Found the 1-5/16” socket needed at a local pawn shop - this was back in 2004. Although my box is a replacement, and I don’t know the date code, the nut came off of the original box.
Richard
Thank you....Joe
