Author Topic: Floor Pan  (Read 3341 times)
DomX77D80
Floor Pan
« on: February 03, 2019, 10:37:21 PM »
Ello  8)
i start the restoration on my 69 Z28 ,the floor need to be fix it (front and rear)  ,what is the best compagnie for the floor pan ?
for the value of my car the better is change all floor (one pieces) or fix the old one whit patch floor pan ?
Thank you! ;D ;D
x66 714
Re: Floor Pan
« Reply #1 on: February 03, 2019, 10:56:29 PM »
I guess that would depend on how bad the floor is. Can you post some pictures? I'm a firm believer it try not to lose any more than you have to but sometimes you have no other choice....Joe
DomX77D80
Re: Floor Pan
« Reply #2 on: February 04, 2019, 12:16:42 AM »
My Floor Pan :P
DomX77D80
Re: Floor Pan
« Reply #3 on: February 04, 2019, 12:18:37 AM »
i cut all the rust  :o
the both side are the same problem
DomX77D80
Re: Floor Pan
« Reply #4 on: February 09, 2019, 02:59:57 AM »
Ello frends  ::) do you use the floor pan from Dynacorn 1046A ?
Thank you
Re: Floor Pan
« Reply #5 on: February 09, 2019, 03:17:14 AM »
I've not had the occasion to replace one, but if I did I would likely use the AMD floor pan. I'm impressed with their quality and attention to details in the stampings I've seen.
http://www.autometaldirect.com/amd-floor-pan-w-braces-67-69-camaro-firebird-includes-convertible-plates-p-821.html -
Or use the right or left halves -
http://www.autometaldirect.com/amd-front-floor-pan-half-lh-67-69-camaro-firebird-p-854.html
http://www.autometaldirect.com/amd-front-floor-pan-half-rh-67-69-camaro-firebird-p-855.html
Definitely not for the timid sheet metal guy. Replacing the entire pan makes sense, unless you're into a lot of stitching on smaller panels.
Re: Floor Pan
« Reply #6 on: February 09, 2019, 10:33:49 AM »
Dom, go to Team Camaro and ask question in “body shop” forum along with reviewing Team Camaro “build” forum as many of the builds needed floor or partial floor replacement. I would not do anymore surgery to car before u know what best direction to go.
DomX77D80
Re: Floor Pan
« Reply #7 on: February 10, 2019, 05:56:12 PM »
Thank you 68 camaro is verry appreciate  8) 8)
