Camaro Research Group Discussion => Research Topics & Reports => Topic started by: KurtS on March 23, 2023, 08:37:10 PM
The 68 steering linkage usage is complicated - we've known that and the 68 Z28 usages show that. http://www.camaros.org/forum/index.php?topic=7610.msg187060#new
So let's expand that to all 68's and see what we can figure out
Looking for some vehicle info: body date, plant, manual or power steering, drums or discs, and engine. And the pitman, idler, and steering arms (which connect to the outer tie rods) forging numbers.
My car is on your list, you can update my car, steering arms #3902519 / 20 04D never2manycamaro's
Thanks! Done.
I'm kinda happy that I figured out how to embed that sheet - it automatically updates too!
Kurt. Mine is 519/520 on the steering arms & 581 on the Idler....Joe
68 O7E, Manual Drums, L-30 / M35…Pittman 075 Idler 581 … Still looking for my steering arm pics..Car is away for winter.
Updated. And slowly the sheet fills in. :)
12E LOS ps discs 396/auto 3935075 (Replaced) 3902519 / 20 [Jim]
Found my Steering arms 3302520 /19 - 07E NOR
519 & 520
Kurt - My Z is an 11D build and has the 3935075 pitman arm.
Tony,
Added. If you get the other component #'s, post them up, including off of your L78. :)
Thanks Kurt, will do!
04A NOR Manual Drums 230 L6 Pitman 3935075 Idler 3917581
Added, thanks! If you get a chance to confirm the steering arms..... :)
Will do.
L22 6 cylinder
11E/M35
NOR
Steering arms 3954873
Original pitman and idler are long gone.
