Camaro Research Group Discussion => Restoration => Topic started by: Z10Mike on July 21, 2023, 07:55:21 PM
1. Re: the outboard clips -
Wish I had known about this being such a PITA before I got the front clip and hood on. I've run the gamut searching threads on the net for how to install those stinking things with the fenders on. All original clips and trim pieces so that part of the equation is not in question. If I can get those end screws/clips installed then I'll attempt to drill the locating holes for the remaining clips in the center of the trim.
2. Re: Outboard Screws -
Can someone confirm the size/thread pitch etc. of the 2 screws that attach the outboard lower w/shield trim clips to the door jam at the cowl? Mine have gone MIA and I don't want to auger out the hole with the wrong screw. Are they the same as the attachment screws for the lower trim center clips?
Many veterans of full restorations on this forum so ANY of your insight is appreciated!
I think they're the same as used for the inner clips....https://www.ebay.com/itm/403079898608?hash=item5dd96f25f0:g:CJAAAOSw08FewJPs&amdata=enc%3AAQAIAAABAJpGb%2BzNYQNfOgipGlGi6dc2JG7NhahaEQzNJmlRvs9XXV1o4DQ%2BOOuDwD74U9rP3AQ%2BpCpYvpf%2BzSyk8IohdBOKt04JZlqXdW0Yb%2BZCd1dqsjSBqUNZK8WMYCRx%2BYVOxq39lSdekgsowhaFShBcyjJ085Xj4k2meFvjMEoFU%2BViuRuyN6MFxOufQBeN%2BHPMX2QnwAwvVdYswofLmOZA8Y%2BXkzTfi4I4n1mIdnGthtE2IKPBGtRQRc2YqB617t8wDcyJi8eF0p61BfW2a3o5C4YptInrv2Ita5TKPa%2FUUOcEN%2FLzrftrKH8MkmhJ93m4DuI5MTsA1PcjNiCuDhDsqZM%3D%7Ctkp%3ABk9SR96Uy6mvYg
Not that difficult to do with the fenders on if your fingers aren't too fat....
When I have a question about the correct fastener I go to the AIM and cross reference the p/n to the AMK Catalog. You can download it. The catalog gives you a pic etc too.
When it comes to removing or installing it with the fenders on a Gear Wrench will be your friend.
example:
HawkX66 - I have run through my assembly manuals for basic and RPO assembly and could find no illustration with the windshield trim or its attaching hardware. Mine could be missing. If you know of a sheet referencing this information please reply with the sheet number and I will check my manuals again.
Thanks.
It will not be covered in the Chevrolet Assembly Manual since it was part of the Body build by Fisher.
I also wish we had more part and piece construction details from the Fisher ide of the house, but the Body By Fisher service manual applies to many series of Chevrolet bodies it is of only so much value.
One "HACK" is to Request a Hard copy of the AMK catalog with one of your orders and it can be a visual aide in hardware identification and sourcing similar hardware that will perform same Form/Fit and Function.
I slightly readjusted the front sheet metal to gain better access for the outboard clips. So now I have trim mocked up but still cannot get any confirmation as to what fastener is correct for the outboard locations. The parts houses have replacements for the center clips but no mention of the outboard jobs. Looking for someone in the midst of a resto with the original screws to post a photo of one against a ruler so I have a visual reference to further the search. Any help is appreciated.
here is my take
The ENd trim brackets are stuck on the window lower trim outer.
Your Guess is as good as mine (1968 LOS Z28 Coupe)
169INDY - Thanks for the photo and reply. I'll add this to the information I am gathering.
I think Darrell might have some Data on his Red Cars recent preservations
The outer screws were #8-18 x 1/4 HX WS, AMK # b-2045.
copo - Thanks for the information. Greatly appreciated.
1/4" ??...I retract my statement regarding difficulty (with fenders installed). lol
Found a pic for you that I took a long time ago.
HawkX66 - Great shots of the bracket and the hex head screw that retains it to the A pillar.
BTW...It looks like my brackets got tweaked when the body guy removed them. Your pics will help to get them back to the correct orientation. Thanks again!
You're welcome. Glad to help.
