Camaro Research Group Discussion => Decoding/Numbers => Topic started by: Danzo on September 25, 2023, 03:39:43 PM
Did the assembly line emblem listed above have the part# 8701333 on the backside?
Ty, Doc.
The one sitting on my desk for 40+ years has 8745869 cast into it.
8701333 is a reproduction. William has the correct original part number.
This was attached to the rear tailpan of my 68 as part of Emblem Envy
LoL
Same number as William posted in fact the cast numbers are a bit jumbled up- Strange
William and Jim thank you. Badshifter please do the research before replying. The link below clearly shows this part #
Keep them coming, Doc.
https://www.heartbeatcitynos.com/26540/1969-Camaro-NOS-Z-28-TailLight-Panel-Emblem-GM-Part%23-8701333/
Harsh considering you didn't know the answer either. Just to be clear, the one in your link is not assembly line correct which is what your original question seemed to be asking.
8701333 is the part number list in my 1969 Chevrolet parts book. But i have seen where the casting number is different than the part number that you buy from gm. 1968 Z28 fenders are different between the casting number and gm part number on the box. Thanks William for the great work. Now i have to go out to garage and see what is stamped on the one i have. Always fun to learn somthing new.
Thanks for the scolding Danzo. I can Google and paste as well. The link below clearly shows this part number.
https://www.oerparts.com/product/8701333.html
I can also do what evidently you cannot, and went and pulled the original emblem off of my car and took a picture of the part number just for you.
Is it possible the part number and casting number are not the same?
I am not trying to be harsh or scold anyone. From reply #6 above: "8701333 is the part number listed in my 1969 Chevrolet parts book" The OER emblem is GM licensed so that is why it carries the "GM" part number. The emblem is also incorrect in that the "28" numbers are white and not silver- from the description- (featuring correct red and white z/28 with black accents). I have pulled many emblems off hence my question, has anyone seen that 8701333 number on the back?. Link below reply #3 gives what is in Jerry's book.
Ty, Doc.
http://www.camaros.org/forum/index.php?topic=10705.msg82229#msg82229
There is a 1969 Z28 trunk emblem part number 87013333 for sale on eBay:
https://www.ebay.com/itm/284129321801?chn=ps&mkevt=1&mkcid=28&srsltid=AfmBOor3Zgb5CYVr6Hv8Q6iHQ4gnCO4RI7nttNO2lOYxyTL_cY0NMhFm-6E
Very likely that the casting No. is not the finished part no.
Ty, GMAD, the ebay one you posted has the 8745869 on the back. Jimmy V, that is what I am trying to determine. Lets see some more!
Doc
Hi Members,
Danzo, I also have 8745869 on my original badge that I took of my car back in 2001 when I was restoring it and bought a new old stock with same part number 8745869 on it but this one also had what looks like a large W after the number then had D429 after the W also in the same line. The 9901 was also there on the diagonal slash.
My Original badge is Red and White while the NOS is Red and Silver.
My new old stock front grill badge has part number CV05-EM14 on it and is red and white, while my original off the car has no part number anywhere on back of the badge but all the edges are much sharper than the NOS. Also on the back of the front grill badge of the NOS has 4 round dots cast in it the number 8, the number 2 has 2 dots, the slash has 1 dot and the Z has 4 dots the original one has none.
Both of them are Red and White.
Since a couple of months ago when the badges where discussed on the forum about differences between OEM badges I started to compare all my original badges that I had removed and kept to see what everyone was talking about and noticed that all my original badges where sharper and more defined and since then I have removed all NOS badges and replaced them with my originals pitting and all.
I have also installed all my original front and back side markers after discovering that the original ones and the NOS had the same part numbers but the originals had a circle indentation a little step in them for when the plugged which hold the globe was inserted in and twisted.
I have used emblem 8745869 that was taken off in the early 80's. I have a nos 8701333 that has also has cast number 8745869 on it to. Both silver 28 letters. Hope this helps.
My tail emblem, on the car in '73 when I bought it, "28" is silver, see pics for markings. Known the car since '72 when I first worked on it, long before Trim Parts reproduced the emblems. I have no doubt the emblem is original to the car, which is a documented car. Emblem removed and stored since '81.
Forgot to add the front view -
