Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
What’s in the box?
« previous
next »
Print
Pages: [
1
Author
Topic: What’s in the box? (Read 1028 times)
David K
Hero Member
Dr. Longblock
What’s in the box?
on:
January 21, 2024, 12:41:07 AM »
Sometimes persistence pays off. And while my car isn’t a 69, I got the most elusive and important part.
Tweet
Logged
rare396bronze
Member
Re: What’s in the box?
Reply #1 on:
January 21, 2024, 02:57:16 AM »
Good find. Does the duct have a number on it is so what is the number on it. The duct is the only piece I have not found yet.
Logged
David K
Hero Member
Dr. Longblock
Reply #2 on:
January 21, 2024, 03:49:10 AM »
No number, just the C stamped on the front. Im going to get the broken tab issue resolved. Bronze....is yours a 68 or 69?
Logged
169INDY
Hero Member
Reply #3 on:
January 21, 2024, 03:53:38 AM »
Hens teeth right there!
Logged
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
rare396bronze
Member
Reply #4 on:
January 21, 2024, 05:11:42 AM »
1968
Logged
Hero Member
Reply #5 on:
January 21, 2024, 08:40:18 PM »
Yep, that be one hard one to find or replace. Congratulations....
Logged
R 68Z build-
http://www.camaros.net/forums/showthread.php?t=182584
David K
Hero Member
Dr. Longblock
Reply #6 on:
January 21, 2024, 09:57:58 PM »
Yea folks,we all know it. The good news is I have several appointments for 3D printing companies this week.
Logged
David K
Hero Member
Dr. Longblock
Reply #7 on:
February 03, 2024, 04:27:21 PM »
Scan done. I had to whittle a broken tab -that wasn’t from the piece for mock-up, and the scan shows it. The 3d image will eliminate it so it will be cosmetically correct. So far I like it. Definitely not my forte’ of expertise.
Logged
David K
Hero Member
Dr. Longblock
Reply #8 on:
February 05, 2024, 01:58:17 AM »
In the meantime while waiting for the 3d scan to be finished, I found a few pictures from here for the mount brackets. My car has a power top so I eyeballed it and it took a few Rolling Rocks, but it’s good and secure. I got 1/4” longer screws to get it sinched down. Mocked it up in the trunk and tis werkin. Whatever engineer designed this is a genius, but this bracket is not easy to make, even with aluminum.
I've uploaded a photo of an original for comparison.
Logged
ridesdirt
Newbie
Reply #9 on:
February 08, 2024, 02:17:37 AM »
3D scan is very cool.
Sorry for the side track but I have a quick question about your last post. That looks like a 67 rear defroster switch. Do they mount on a bracket like that? I assumed they just installed directly through the hole between the gauge cluster screws. Which would make it vulnerable to a knee.
Now I am thinking I need to track down another part... or make my own, and I agree, it doesn't look like an easy one to make.
Logged
David K
Hero Member
Dr. Longblock
Reply #10 on:
February 08, 2024, 06:47:15 AM »
The bracket is only for power convertible top applications. Otherwise, the switch is mounted in the spot where the top switch normally goes. Do you need a bracket made?
Logged
David K
Hero Member
Dr. Longblock
Reply #11 on:
February 11, 2024, 05:45:07 AM »
Fixed the tab for full mock-up. Pulled the sill plates, ran the wires correctly in the channel, while simultaneously installing the rear speaker wire.
Drilled a big hole, installed the setup, smoke test completed, almost done.
Logged
Print
Pages: [
1
« previous
next »
General Discussion
What’s in the box?
