Author Topic: Survivor '69 Coupe with a 6-cylinder and a 3-speed manual  (Read 35650 times)
MO
Re: Survivor '69 Coupe with a 6-cylinder and a 3-speed manual
« Reply #150 on: April 12, 2023, 05:18:51 AM »
Not likely this year, but maybe next; you never know. But I might make the Camaro National's with a little good timing though if you have plans for that. It would be my pleasure to hook up with you, Charlotte and David.
68SixBangerRS
  • Camaro Project from HELL
« Reply #151 on: April 14, 2023, 11:29:48 AM »
The "new" 230 engine is completely original.  The engine's stamp indicates it was assembled on May 15th, 1970 at the Flint, MI plant.  It also has a partial VIN...something that was not always done on 6-cylinder engines that I have seen (and owned).
68SixBangerRS
« Reply #152 on: April 14, 2023, 11:33:10 AM »
The engine is completely original, including its starter.  It is a 40k mile engine...an incredible rarity these days.  The starter cleaned up beautifully.  Its date indicates it was assembled on May 5th, 1970.
68SixBangerRS
« Reply #153 on: April 14, 2023, 11:40:37 AM »
Since the '70 engine has a good carb stove, I decided to use its beautiful air cleaner.  The paint is nearly perfect and it really shines.  Note the date code in green paint which shows it was assembled on the 122nd day of 1970.
68SixBangerRS
« Reply #154 on: April 14, 2023, 11:42:53 AM »
The fan was cleaned with polishing compound and Turtle Wax.
68SixBangerRS
« Reply #155 on: April 14, 2023, 11:46:06 AM »
Dropping the 230 in was easy...it slid right in.
68SixBangerRS
« Reply #156 on: April 14, 2023, 12:37:19 PM »
A close-up of the carb's heat shield.
68SixBangerRS
« Reply #157 on: April 14, 2023, 12:43:37 PM »
I am happy to report the engine swap was a complete success.  The 230 produces excellent power and easily keeps up with modern traffic.  I can't really tell much difference between the 230 and a 250...the best way to drive it is to give it plenty of pedal off the line and shift to 2nd at 20-25 mph, then shift to 3rd at 40-45.  It cruises easily at 75, but it seems happier at 65-70.  Most drivers follow behind at a close distance to watch it glide down the hiway.  It produces many smiles and thumbs up...I like it a lot.  :)
MO
« Reply #158 on: April 15, 2023, 07:06:51 AM »
Awesome! Thanks for the follow up!!
David K
  • Dr. Longblock
« Reply #159 on: April 15, 2023, 02:11:57 PM »
Fantastic news!
« Reply #160 on: April 15, 2023, 04:22:58 PM »
Sweet Progress. & Having Fun for sure
David K
  • Dr. Longblock
« Reply #161 on: April 15, 2023, 05:17:34 PM »
I’ve never seen the carburetor heat shield before…..found it in a parts book for 1970 models.
68SixBangerRS
« Reply #162 on: April 16, 2023, 06:33:04 PM »
David...you are correct, Sir...the heat shield is from a 1970.  I swapped in the 230 "as-is"...in its original 1970 configuration.  It has an obnoxious exhaust leak which has prompted me to replace the manifold gasket (progressing nicely...should be done by this evening).  The leak didn't prevent me from taking Charlotte out and driving her for a shakedown run of 50 hiway miles.  The 230 stumbled some from idle up to middle RPMs, which I believe may be due to the leak.  The original Monojet carb from the 250 is going on the 230, and I am removing the non-1969 items like the CCS solenoid and the anti-dieseling solenoid, but I am considering keeping the heat shield as I think it's a good idea and may improve the car's drivability in summer conditions.
Thanks to all for your kind words.  I think Charlotte is going to attract a great deal of attention due to her now unusual drivetrain.  I am glad she is appreciated on here for her originality.
David K
  • Dr. Longblock
« Reply #163 on: April 16, 2023, 10:21:37 PM »
I would check the nuts that hold the “wing washers” to the cylinder head. They do tend to loosen up over time. Verify the carb rubber plugs/vacuum advance hose is good.
Have you checked the dwell for the points?
68SixBangerRS
« Reply #164 on: April 17, 2023, 06:37:38 AM »
The points looked like new...no appreciable wear or burn spots.  The manifold gasket still had factory orange paint on it (the original).  Once the manifold was removed the source of the leak  was obvious...the gasket was compromised in two places (see first photo).  Our weather changed from 67 deg and sunshine at noon to 50 deg with rain and high winds at 2pm, so the replacement project will have to wait until tomorrow.
