Author Topic: Steering column lower bearing original 1967  (Read 532 times)
almos
« on: October 30, 2023, 12:43:33 PM »
Hello.
I having trouble to put back together my steering column. It's 5 years since I took it apart and I remember I  took apart the lower bearing assembly, but I can't find the pics how it looked like. Anyone has a good quality photo of the original 67 Camaro non tilt, column  bearing?
Thank you
Re: Steering column lower bearing original 1967
« Reply #1 on: October 30, 2023, 08:26:33 PM »
Aw Snap, Your separated the Races and Cage and Balls.  I was not aware that this was "serviceable".  While cleaning mine in a solvent tank balls fell out and the were no longer 'spherical' and the entire bearing required replacement. Heartbeat and SS396.com are sources.
« Reply #2 on: October 30, 2023, 11:15:58 PM »
I've replaced the lower bearing with the upgraded one. Ground Up and others have it.
« Reply #3 on: October 31, 2023, 12:13:08 PM »
Ground Up & ss396 are one in the same which is where I got my replacement.
Preservation of a 68 Camaro Thread
Comparison photos
almos
« Reply #4 on: October 31, 2023, 07:53:15 PM »
Thank You guys. I put it back together greased up well. It works great.
