Author Topic: vaccum hose connection  (Read 5958 times)
sbmiano
« on: April 22, 2014, 03:06:02 PM »
I saw a picture of john Z engine and noticed that the hose off the vac advance on the distributor goes to the carb and I am confused.  I thought it went to the metal tube that is capped so it seems on John Z picture of his engine??
69 z28  Van Nuys 04D Legends Certified
09 viper 5k miles
Re: vaccum hose connection
« Reply #1 on: April 22, 2014, 04:23:47 PM »
Those are two different setups - one for (correct) showing with the original vacuum advance connected to the "ported" spark port on the carb base (top photo), and one for driving, with the vacuum advance connected to the full manifold vacuum source hose that feeds the choke pull-off diaphragm via the tee that originally fed the diverter valve diaphragm (bottom photo).
sbmiano
« Reply #2 on: April 23, 2014, 05:03:49 PM »
thanks John, I was afraid I had it wrong for the upcoming nationals
09 viper 5k miles
Mr 396
« Reply #3 on: August 10, 2014, 12:47:58 AM »
Just what I was looking for. Thanks
L78 steve
« Reply #4 on: August 11, 2014, 05:07:33 PM »
So is the EGR hose holder clip only on big block?
69 Z/28 Dover White. SOLD
« Reply #5 on: August 12, 2014, 04:43:49 PM »
No 1st-Gen Camaro had EGR, but the L-78 had a clip for the PCV hose that mounted under the right front carb nut.
L78 steve
« Reply #6 on: August 13, 2014, 02:18:07 AM »
Yes PVC, Thanks for the correction.
luv2sixty9
« Reply #7 on: August 21, 2014, 12:36:53 PM »
[/quote]
John,
Did the PVC Hose bracket come on a 69 Z28 also.
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
« Reply #8 on: August 21, 2014, 04:27:41 PM »
John,
[/quote]
Nope - it was only used on the L-78.
Pacecar
« Reply #9 on: August 21, 2014, 07:12:51 PM »
Assembly manual shows it for the L78. Bracket is mounted to the valve cover to hold the tube
« Reply #10 on: August 21, 2014, 10:15:55 PM »
Are you referring to the PCV hose bracket for L78? As John mentioned its attached to the right side carb nut.
