Camaro Research Group Discussion => General Discussion => Topic started by: RikerZ28 on January 31, 2024, 08:28:06 PM
Gentlemen, Ladies, and wiring experts, I'm Confuse and need advice.
Am replacing the Alternator 2 wire connector that goes between the alternator and the external voltage regulator.
Looking from the rear of the alternator, cast into the case is an (R) on the left and an (F) on the right.
Looking at the 1969 Camaro assembly manual the wiring diagram show that the (Dark Blue Wire) is the going from the regulator (F) terminal to the (R) on the alternator and the (white) wire is going from the regulator terminal #2 to the (F) on the alternator.
Am I correct and stating this is wrong and is backwards. Attached picture.
The second attached picture is confirming that the (F) on the regulator goes to (F) on the alternator (Dark Blue Wire) and the regulator terminal #2 (white wire) goes to the (R) terminal on the Alternator. Correct
I purchased a new connector and the (Dark Blue wire) and the (White wire) are reversed and look to follow the assembly manual can I assume all I have to do is reverse the two wires making it correct?
Bob
