Camaro Research Group Discussion => Restoration => Topic started by: upscope757 on March 29, 2020, 02:12:17 PM
All, trying to refurbish my rear window regulators. Any tips? Any grease recommended? Thanks!
I soaked mine in carb cleaner. They look brand new. Haven't greased them yet...Joe
Tks! I suppose a good axle grease would work well.
I would use white grease
Perfect
Lucas Oil White Lithium Multi-Purpose Grease - 8 oz
Part #: LUC 10533
Line: Lucas Oil Products
Thank you!
In the transmissions (the gear box) I use Mobile high tack gear grease called black pearl.
On the open tracks I use White lithium.
2nd what James recommended. Same what I used
Usually I find chunks of grease coming out of the regulator transmissions - I use a pressure washer and steaming water.
If you lube and adjust your regulators correctly the windows will operate without having to "help" them up.
