Author Topic: 67 Master Cylinder  (Read 3650 times)
Daral
67 Master Cylinder
« on: October 05, 2007, 01:18:36 PM »
What casting numbers were used on the master cylinder of a 67 with power drum brakes?  Mine is 5460465 and has a BS stamp.  I think this decodes to a 67 Firebird with power drum brakes but I know of another 67 Camaro with the same casting number and stamp.  Did they use this casting number on both Camaros and Firebirds?
67 RS/SS 350
Steve68
Re: 67 Master Cylinder
« Reply #1 on: October 09, 2007, 11:55:52 PM »
Daral
Do you believe this mc could be original to the car?  Can you see/read the date code on the mc if one is there?  What is the build date on your car again?
Daral
« Reply #2 on: October 10, 2007, 12:43:48 PM »
The build date on my car is 01B (2nd week of January 67).  The date code on my M/C is 341 which I think is December 7, 66.  That would be reasonable for my car.  I do not know if the MC is original but I suspect it is.  I have receipts for the work done on my car by the previous owner dating back to 1975.  I suppose the M/C could have been replaced prior to 1975 but that doesn't seem realistic since at most it would have been 8 years old and they rarely go bad.
Daral
67 RS/SS 350
