Camaro Research Group Discussion => Restoration => Topic started by: lakeholme on June 26, 2008, 01:05:01 AM
On bumpers (and other chrome) that really aren't pitted or flaking, what kind of success have you had with "jeweler's rouge" type polishing (not the stuff like Mothers where you can also polish glass and plastic) to take off minor scratches and tarnish? What are the major drawbacks? If you've done it, is it worth it? What polish and polishing medium did you use? ???
(We've got enough body work done on the 68 now to where I need to make on my mind on what I'm going to do about the bumpers, etc. They really aren't bad... And remember my 68 is a driver...)
Appreciate any feedback... ;D Really appreciate kowning about your experiences.... ;D ;D ;D
I've had good luck useing x-tra fine steel wool. It even took out some minor pitting. dennis 68 RS-SS L35/M20
When you use the steel wool, do you use it dry or do you wet it with something like detailer?
I USED IT DRY WITHOUT A LOT OF PRESSURE, THEN USED SIMICHROME POLISH.
Once you get it the way you want it, don't use "polish" again - "polish" contains abrasives and will eventually remove the clear chrome layer and expose the underlying bright nickel, which then oxidizes, gets dull, and starts to pit and corrode. Just use "wax" (not "polish"), and lots of it.
Once you get it the way you want it, don't use "polish" again...
True, but what polish and procedure works best to get it the way you want it?
Simichrome, Wenol, and Nev-R-Dull are examples of "polish" that have very mild abrasive qualities; make sure the chrome is clean first so you don't rub in dirt and create more scratches.
